  #1
Old October 1st, 2007, 09:42 PM
242 242 is offline
Default 92 Yamaha 225 knocking noise
Help! I just purchased a 92 yamaha 225. The compression test was good reading 4 cylinders at 125 one at 127 and one at 123. When we put it in the water the other day we could here the slightest knocking noise coming from under the flywheel. My mechanic thought it could be the upper bearing on the crank and that this could be replaced without tearing the engine apart. He came back and told me today that if the bearing is bad it is most likely a sign of a bad crankshaft all together and the engine would have to be torn apart. I have a second opinion coming next Monday from a local marina that has certified Yamaha techs. Any ideas or comments would be appreciated.
  #2
Old October 1st, 2007, 11:38 PM
242 242 is offline
Default Re: 92 Yamaha 225 knocking noise
bump
  #3
Old October 2nd, 2007, 02:46 AM
rodbolt rodbolt is offline
fresh or saltwater engine?
the upper mains just dont go bad. lowers do but rarely uppers unless water intrusion is a culprit.
  #4
Old October 2nd, 2007, 08:08 AM
242 242 is offline
Rodbolt,
Thanks for the reply. It has never seen the salt but will now be in the salt. What would you guess that noise to be. It sounds as if it is right under the flywheel.
  #5
Old October 3rd, 2007, 02:08 PM
beats me, but its not hard to remove the flywheel,check the stator and pulser screws. if ya wish from there, the upper bearing is not hard to remove.
  #6
Old October 4th, 2007, 11:36 AM
giantuna giantuna is offline
I got the same noise.
Is it a knock or a tick?
Heard that if it was the staor then it wouldn't run at all, don't know what to believe.
What are the pusar screws? Is that what mounts the flywheel?
  #7
Old May 18th, 2009, 08:37 PM
dusouth dusouth is offline
I had the same noise yesterday that just appeared. Well i found it realy quick when the rod come out the side of the engine. Thats probably if i had to guess the number 2 piston on your engine making the noise. it is the next bearing in line there. Hate to be the bearer of bad news but good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Knocking noise at idle Yamaha 175 Hoss IV Yamaha & Suzuki Outboards 7 June 1st, 2007 06:34 PM
Knocking Noise 89webb Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 May 16th, 2007 11:09 PM
overheat-knocking noise Phantom17 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 September 4th, 2005 04:45 AM
3.0 Cobra knocking noise VMAX Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 October 1st, 2002 05:10 PM
help with 30 hp evinrude knocking noise MAKO72 Johnson & Evinrude Outboards 8 April 1st, 2002 05:53 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
