1991 70hp force outboard starting problems
sjoh0824
I just bought my first boat a couple of weaks ago and it started and ran fine. Now when I try to start it it just clicks once and then no more clicks until an hour or so. I tried jumping it and it seems as though the starter is not strong enough to turn it but when i take the spark plugs out it turn fine. I purchased a new battery and the same I checked the solenoid and it is getting power. Do you think the starter is bad or could there be more problems. thanks
roscoe
Re: 1991 70hp force outboard starting problems
Starter could just be dirty inside.
You could clean it out, or take it to a starter/motor/alternator repair shop and have them do it.
