I'm recommissioning a boat with two 5.7L MIE, 1995 inboards after several years of layup. The engines (named Burt and Ernie--port and starboard--by my 4 year old son) have been turned consistently over the years just not started. Raw water cooled. Ran in saltwater, then fresh.
I'm trying to decide whether or not to replace the intake manifold, after finding some loose rust debris (scale) when inspecting inside the thermostat port, and through the holes that fit to the circulating pump. I have a strong industrial vac that will get some of it out, but should I go ahead and replace it? If so, is this a big job? At this point I'm going by the "if it ain't broke" principle, but I'd hate for some other rust derbis to clog up some port once underway and have to replace it later. There's no evidence of any seal or gasket failure. The outside appearance of both engines is quite clean in fact.
Thoughts?
Thoughts?
