  #1
Old September 30th, 2007, 03:33 PM
stl stl is offline
Default 1973 evinrude 18 hp carb rebuild
I started the carb rebuild on this motor, and I already have run into a snag. I can't seem to get the old needle valve seat off. it is on really tight and I am starting to chew it up a bit. Has anyone run in to this problem, any suggestions?
  #2
Old September 30th, 2007, 03:38 PM
samo_ott's Avatar
samo_ott samo_ott is offline
Default Re: 1973 evinrude 18 hp carb rebuild
Yes, they can be snug but they do come off. Also they're quite soft which also can be an issue. Try small vice grips as you are replacing it so it does not matter if it gets a tad beat up, as long as you get it out. You are replacing it, right?
  #3
Old September 30th, 2007, 03:40 PM
stl stl is offline
Yea I was planning on replacing it. I think i have to now cause it is all chewed up. I'll try the vice grips. I have rebuilt a couple of carbs, never had this problem.
  #4
Old September 30th, 2007, 04:13 PM
stl stl is offline
The vice grips was a no go. I am starting to panic cause the seat is really chewed up now any more ideas?
  #5
Old September 30th, 2007, 10:32 PM
stl stl is offline
I had to walk away from it for a few hours, because the curse words were really starting to fly. I ended up putting it in a vice and tapped it with a screwdriver and a hammer at the right angle and it came off. I don't know why I didn't think of that before. Hopefully no more hang ups but I will be sure to let you know if there are.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 50hp evinrude carb adjustments. 94saleen Johnson & Evinrude Outboards 1 July 7th, 2007 04:40 PM
'84 Evinrude Carb Rebuild blhpzlb Johnson & Evinrude Outboards 2 May 10th, 2005 07:07 PM
? carb rebuild 150 evinrude guyo Johnson & Evinrude Outboards 7 May 10th, 2005 03:04 AM
Carb rebuild ?'s on Evinrude vro 140. nivram Johnson & Evinrude Outboards 9 April 20th, 2003 02:41 PM
Evinrude 25HP 1973 Carb jet sizes G DANE Johnson & Evinrude Outboards 0 April 14th, 2003 10:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
