I Have A Mercury 75 Hp And I Need A Break Down Of How To Take The Stator And Flywheel Off My Sn# A190680 And The Years Is Of 84 To 88 Itz A 4 Cylinder! Thank You Mercslive!
You need to remove the nut and use a special puller that threads into that cavity. Once off, the stator is probably held on with four allen screws and the wires are probably connected with brass nuts.
