Mixing mineral oil and synthetic oil
I have 3 gallons of gas mixed with pennzoil mineral base tcw 3. And another 3 gallons of gas mixed with pennzoil synthetic tcw 3. They are both mixed at 50:1 ratio for my johnson 9.9.
Can I safely combine these two mixes into one tank for use, or could it damage my 2000 outboard?
Thanks.
studlymandingo
Re: Mixing mineral oil and synthetic oil
There is no issue with mixing the two types of oils.​
Texasmark
Some containers state they mix readily and if you see any "Synthetic Blend" oils they are just that.
HTH
Mark
dajohnson53
Is it not true that any oil (synthetic or mineral) that is rated tcw3 is fully compatable with any other oil with that rating?
