  #1
Old September 29th, 2007, 02:49 PM
gunthagunth gunthagunth is offline
Default Evinrude 70 Blown#2 What are the options?
Hows it going? I have a 18' center console with a 70 evinrude model number E70tlend. Looks like its a 92. I pulled the cover off of the pistons and found the number 2 piston to be bad. Looks like 1/2 inch wide score is down the cylinder wall. Less than 1/16 deep. I was wondering what the options would be. Is there a way of sleeving the cylinder? Should I hone it out and get a bigger piston ring and new piston? Or is it not even worth tinkering with? I began to pull pieces off to free up removing the power head but I stopped until I get a manual. I have no clue about boat motors. I am a jeep guy . Thanks for your time. I will get a pic of the cylinder wall.
  #2
Old September 29th, 2007, 02:57 PM
Default Re: Evinrude 70 Blown#2 What are the options?
Here you can see the #2 piston. The top has melted some down to the ring and it is scored about a inch maybe more wide. The metal made its way into the small port on the wall also. Hopefully I can dig that out easy.
  #3
Old September 29th, 2007, 07:06 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Kinda typical for those motors that are run a lot in the mid range. Or with the wrong spark plugs. Or with dirty carbs.
It'll most likely clean up with boring. They'll offest bore to try and pick up as much as possible from that side. If it won't clean at .040 then you can sleeve it.
From those shots it just looks like a standard rebuild with possibly a sleeve.
  #4
Old September 29th, 2007, 08:31 PM
Thank you very much for the reassurance. This motor is much newer than my spare and even tho it is blown with a new piston I would have more faith in it. Thanks ~Jason
  #5
Old September 29th, 2007, 08:42 PM
Benny1963's Avatar
Benny1963 Benny1963 is offline
seems a little small for centerconsole 18 ft what is it rated for
i have a 17 ft mckee and it rated at 135 im running a 150 and all out it runs
40 was cosidering going smaller to save gas but dont want to get below 30 mps ,what kind of speed were you getting out of it and what type boat
and hull designe do you have ,so that i might compare ,mine runs that 40 mph
fully loaded 4 people and gear .
thanks benny b
__________________
Benny B
  #6
Old September 29th, 2007, 11:23 PM
1730V 1730V is offline
I agree a 70 may be a bit on the small side for an 18' boat. That engine does not like to be lugged and scoring number 2 may be a result of that.
When it is rebuilt, make sure the carburetors are gone through and a new water pump is installed.
Also, after break in, prop it to turn a minimum of 5800 RPM at wide open throttle. That will help with the lugging.
  #7
Old September 30th, 2007, 09:02 AM
Points are definetly taken. It will be getting rebuilt over the winter. I have to get a factory service manual for the motor and begin rebuilding the carbs and pull apart the motor.
The boat I was told is a flat bottom but it is round along the sides. The front has a V-hull that flows into the flat bottom. Not sure what the style was built for. It was built on Cape Cod. 1977 Pointer.
  #8
Old September 30th, 2007, 09:05 AM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
21' w/ blown 4.3l engine... swap options? dr.fowler Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 24 July 23rd, 2007 03:47 PM
evinrude simplex options kurt spine Johnson & Evinrude Outboards 2 July 15th, 2007 06:25 AM
Evinrude Re-build Options chris goodwin Johnson & Evinrude Outboards 1 May 29th, 2004 08:58 AM
85 Evinrude VRO replacement options..... Luna Sea Johnson & Evinrude Outboards 5 December 25th, 2002 05:42 PM
3rd problem with my Evinrude, What are my options? FNG Johnson & Evinrude Outboards 1 August 27th, 2001 07:34 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
