  #1
Old September 28th, 2007, 06:30 PM
lakesidefoxfarm lakesidefoxfarm is offline
Default 1997 Mercury 15hp Water Pump Issues
This motor has been sitting for approx. 3 years since it was last ran. It is a 1997 Mercury 15hp. There is no water stream coming out of the motor. I figured the impeller was bad so I replaced it. While I had it apart I checked the water lines to make sure they were not plugged. Put it all back together and it's still not working. Should I have got the complete water pump rebuild kit or is there something else I should be looking into? Thanks Gary
  #2
Old September 28th, 2007, 07:05 PM
emckelvy emckelvy is online now
Default Re: 1997 Mercury 15hp Water Pump Issues
This motor has a thermostat so perhaps you should check that as well.
You could try starting the motor with the thermostat and its cover removed to see if water is pumping up to the powerhead.
If I recall you don't get a lot of water out of the telltale until the 'stat opens. If the bleed hole in the 'stat has plugged from prolonged sitting, you probably would get nothing out the telltale until the 'stat opens.
If you don't get water pumping up into the powerhead out the 'stat hole, time to pull the lower unit back off and blow air up the water supply tube (or hook the garden hose up to it) and check for flow. If you verify flow thru the powerhead, you probably have some kind of issue with the pump.
HTH..........ed
  #3
Old September 28th, 2007, 07:16 PM
I did remove the thermostat and no water came out. I also blew air up through the water port and I did feel it coming out where the thermostat is located.
  #4
Old September 28th, 2007, 08:14 PM
bgbass.1 bgbass.1 is offline
did you make sure fins on pump facing clockwise when your looking at it? just a thought
  #5
Old October 3rd, 2007, 02:15 PM
Unhappy Re: 1997 Mercury 15hp Water Pump Issues
Just so I understand when I look at the fins they should be facing clockwise. This creates a pushing motion versus a sweeping motion correct? One thing I did notice was when the motor was running there was water flowing out of the 2 small holes on each side of the motor just above the lower unit. That doesn't seem right to me. I also noticed that the top seal on the impeller housing was sloppy loose. Is it possible that the seals to the housing are shot which might reduce the suction needed to get the water to the block? This seems like such a simple cooling system. Why is it so hard to figure out then?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1997 Evinrude 200 water pump dingbat Johnson & Evinrude Outboards 0 May 2nd, 2007 11:35 AM
OMC water pump shaft issues Capt Bert Boat Restoration and Building 3 August 17th, 2006 08:26 AM
OMC water pump shaft issues Capt Bert Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 14th, 2006 03:20 AM
converting a mercury 15hp (1997) with tiller to steering wheel airkampos Mercury & Mariner Outboards 3 August 14th, 2005 10:04 AM
Water pump issues 115hp aanda6 Johnson & Evinrude Outboards 9 August 7th, 2005 02:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
