I finally decided to try and make my old 14 foot crestliner ship shape again. Its been neglected for years and had about 6 inches of old rotton leaves in it. I cleaned them out and several dark spots are cleaning up well using a sand blaster. My questions is .after I blast it clean what should I paint it with to not only cover the metal but seal it real good? thanks
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Thanks, I will get the primer you reccommend. I dont have a pressure washer so I figured a light sand blasting and then a good soap and water washing will leave it ready for the primer. I will post a few pictures as progress continues thanks again.
I used to rebuild old land rovers, which are aluminum ; sand blasting aluminum makes for a pretty rough surface. You probably need only clean the boat, prime and paint it. Napa sells a good etching primer in rattle cans or gun sprayable.
Yes I agree,but Im just using the sand blaster on the inside and there the paint being a little ruff is ok . The out side will be sanded real good before the primer.
