aggiedave98
- Jul 14, 2003
- 231
I just got a new I/O deck boat with 1 main battery and 2 batteries for the trolling motor.
It's got an onboard charger for the trolling batteries. I'm assuming the way it works is the alternator is only charging the main battery right? Then you troll with the other 2 batteries and they drain down. Then you get home and charge them up right?
Do I need to get a trickle charger for the main battery? What about for the trolling motor batteries? Let's say I go a couple of months between using it? How does that change things.
thanks.
thanks.
