My 2003 90hp TLDI has developed a starting problem recently. I know I need to take it in to my dealer eventually, but I'm not sure there's enough of a symptom yet for him to diagnose. I have a two battery system. The starting battery is a group 27 with an excess of CCA capacity, and the house battery is also rated at the mfgr's CCA specification. I towed the boat 500 miles up to our camp in Canada two weeks ago. We got there in the evening, loaded the boat, it started up normally, and we went 7 miles downriver to our camp. Next morning, after the boat was in the water all night on a mooring, and everything had a heavy layer of dew on it, I went to start the boat on the group 27 battery. It turned over very slowly but wouldn't fire, and the low voltage alarm went off while cranking. I switched to the other battery....same thing. It would crank a few times, the alarm would sound, and the motor wouldn't fire. I switched to both batteries, and the motor started. It ran fine every time I re-started it the rest of the day. The next morning, and every morning afterward, it was the same story...hard to start on either battery, but would start with the battery switch on the "both" setting. I knew my battery switch was getting corroded, so I installed a new one when I got home a week later. I also charged the starting battery on the trickle charger for a few days and cleaned and tightened the battery connections, but the problem persists on a cold start only. Both of my batteries are fully charged, and read 12.6 volts when I got back from vacation, so I don't think that the battery condition was at fault. I keep hoping the problem will get worse so it can be diagnosed, but after the first cold start in the am, it will start normally the rest of the day, even if its shut off for several hours in between.
Any ideas? Or should I just take it in to the dealer now?
