looking for help and suggestions!!!!!!!!!
125 hp force on 18 ft center console. boat connot get out of hole. changed props, have 124 psi at each cyl. if i pull top two plug wires while engine is running nothing changes. if i pull bottom two plug wires force engine wants to stall. so those two cyl are firing. could this be a stator issue or trigger issue ? after boat planes off i get 5500 rpm at wot. please respond. thank you. fm330
