  #1
Old September 24th, 2007, 06:50 PM
lifeisfun's Avatar
lifeisfun lifeisfun is offline
Default 50 ELPT 4-Stroke Mercury opinions needed
Hi folks,
I'm considering purchasing boat with 1999 50 ELPT 4-Stroke Mercury
Owner claims that there is 65hrs on the outboard ( looks great)
Is this good outboard ?
I would prefer Honda or Suzuki but the boat is very nice
Thanks
  #2
Old September 25th, 2007, 12:21 AM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
Default Re: 50 ELPT 4-Stroke Mercury opinions needed
It should be an ok motor if you don't mind oil changes and valve adjusting. I have a 1996 50hp 4S Mariner/Merc (actually a relabled Yamaha to Mariner/Merc) bought new. It's a carbed version with the standard ratio lower unit. Nothing spectacular or bad with it. The plastic body fuel pump is easy to hit and break if you aren't careful putting the cover on. I learned that the first week. The water pump impeller is very tiny (size of a 3hp Johnson impeller...no joke) and tolerates only sub micron wear before needing a change...learned that the first yr.
The early Merc 50 4s had a known problem with corrosion/electrolysis where the waterpump tube plugs into the powerhead...it swelled up and blocked water. It didn't happen to mine and I don't know if 1998s were included. It was the wrong seal material or something and happened the first yr or so. Merc fixed the ones that people squeaked (commercial rental fleets) about and others (us common folk) payed the $600 repair bill to fix because it was just barely out of warranty. Typical Merc fashion...just like the famous stator problems that happened in earlier yrs. Deny the problem to the world and repair privately to only the few who complained with reverence. Would I buy another? Not a 4 stroke again, especially a Merc. This is my mellow version btw.
bp
  #3
Old September 25th, 2007, 06:17 AM
lifeisfun's Avatar
Thanks for taking the time to respond !
I guess I'll pass on it
  #4
Old September 25th, 2007, 09:21 PM
I didn't mean to imply it is a bad motor...mine is older, has lots of hrs and has been reliable. It has too many plastic parts for my liking but they haven't given a problem except on the fuel pump housing I posted about. It did strand me once the first yr but I found it to be a loose harness connector under the hood. All I did was spread the hollow male pins to make them fit tight...problem gone. I'm just not a fan of Merc Marine Inc, their engineering or 4 strokes anymore.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1997 mercury marine force 120hp elpt hoyt101 Force & Chrysler Outboards 2 July 17th, 2008 12:36 PM
1983 mercury 90 elpt rpms drop can somebody help? myebay Mercury & Mariner Outboards 1 May 29th, 2007 06:30 PM
Mercury 50 ELPT 4S flywheel magnet rcutting5 Mercury & Mariner Outboards 1 January 26th, 2006 10:23 AM
Power Trim "sag," 1990 Mercury 60hp ELPT olyerickson Mercury & Mariner Outboards 1 August 17th, 2004 12:58 PM
1996 mercury force 75 ELPT- Carb problems ckirby Mercury & Mariner Outboards 1 April 15th, 2003 08:57 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
