Re: 1960 Evinrude 40 HP, play in the crank
Well, about what Joe just said: That spring at the bottom of the crank is to keep the carbon seal up against the bottom of the lower main bearing. The seal is supposed to slide up and down on the shaft if the shaft moves up and down. It is true that the spring tends to hold the crank down, but if you lift with more force than the weight of the crank plus the rate of the spring the crank will move up.
I'm millimeter challenged too, but looking at a ruler I'd say two mm is perfectly normal.
EDIT: ok, I looked it up and 2mm = .0787". That is way more than the .011" specified in the book. But I'm sure I've seen them run with considerably more than that.
