Hi there, I have a 1985 Johnson 50hp BJ50BELCOB here in the UK and have just replaced the VRO with a standard fuel pump and would like to know the fuel line sizes for the following OMC part numbers, as the parts list I get access to just lists the part number and not the sizes and as I am nowhere near an OMC dealer if I know the sizes I can get them from a local marine dealer.
It is also a bit more confusing as the diameters of for example the fuel pump input connector is larger than the outlet whereas I though they would be the same!?. Anyway they are:
322725 (hose that runs from the fuel connector on the casing/body to the fuel pump inlet)
327414 (hose from fuel pump outlet to the tee)
319733 (the three hoses from the tee to upper carb, lower carb and primer solenoid)
326449 (small hoses from primer solenoid to carbs)
thanks for your help!
Ivan
Ivan
