Re: 1991 200 hp Mariner running hot
Yes! You have a poppet valve. It is on the lower starboard side of the block, look for a plate that looks like a figure "8", with 4 small bolts holding it on. The poppet valve will (should) open at about 3000 rpm and relaese excess water into the exhaust. Pretty easy fix, remove the starboard side lower cowling for easier access, just four small cap screws to remove, nothing to disconnect.
