  #1
Old September 21st, 2007, 05:13 PM
1531665anthony 1531665anthony is offline
Default 1994 115 mercury missing and alarm going off not reaching 5200 rpms only 4400 rpms
i just picked up a 17 whaler 1973 with a 1994 mercury 115 engine. it is all in very good condition, but the last owner only ran the motor on the muff a few times a year for two years. i looked it over and it looked fine. i put a 12 galon tank mouler fueled up 89 octain and qicksilver oil all new. man, it cranked right up i headed out gave it the gas and up we went but it started missing. it caught up and ran fast, but each time i tried to get it up it would miss and than find it self and run but the max rpm would be 4400rpm i thouht it needed to be run. was that a mistake? i ran it for 2hours stoping starting pumping the ball trying to run it out of her. when she was running she ran great but never could get 5200 rpm. on the way in she really seemed to stop missing. at the end i was taking it easy 3200rpm and the alarm goes off and stayed on until i walked it home slow.
someone told me if it is a fuel issue i could be in trouble because the fuel goes in to the carbs on the bottom and it was not getting fuel to the top carb; therefor, the top pistons were not being lubed from gas and oil and i could have damaged the top of the head. what should i do. bring it to a mercury man. are change the plugs and fuel filter and try it again. it ran fine on the muff after this trip. i cleaned the plugs and it really fired up. no missing and alot of reaction to gas. no alarm sounding off. do you have any advice?
  #2
Old September 23rd, 2007, 10:22 AM
Texasmark's Avatar
Texasmark Texasmark is offline
Default Re: 1994 115 mercury missing and alarm going off not reaching 5200 rpms only 4400 rpm
Sitting up that long could have resulted in varnished carbs which results in clogged jets.
Higher speeds under loads like you mentioned require more fuel. If the jets are clogged, the engine cannot supply enough fuel to run at the higher rpm's under load.
What you say is true about a carb not supplying fuel to that cylinder. Removing the spark plug and looking into that cylinder may allow you to determine if you have any damage. Look at the plug tip for metal shavings...shouldn't be any, and look at the sides of the cylinders for scoring....should be mirror shiny. Look on the head of the piston for alum chips....shouldn't be any.
Rebuild your carbs and might as well get a fuel pump repair kit.
HTH
Mark
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1994 115 missing and alarm going off not reaching 5200 rpms only 4400 rpms 1531665anthony Mercury & Mariner Outboards 1 September 25th, 2007 07:43 PM
97 150 oceanrunner only reaching 2300 rpms baxter66 Johnson & Evinrude Outboards 2 December 4th, 2005 05:55 PM
1981 Johnson 115 Hp Not reaching RPMs RickN Johnson & Evinrude Outboards 4 September 27th, 2005 12:55 AM
5200 rpms on Chevy 350 AdamB Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 August 27th, 2004 09:33 AM
Not reaching full rpms pjhmth Mercury & Mariner Outboards 3 June 12th, 2001 05:14 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
