shooterbiff
- Aug 19, 2007
- 6
My older 70 won't start sometimes, but usually if you go for a drive, cross some speed bumps or something it will fire right up - once on the water it has not failed to start - yet. Took it to local mechanic after trying starting fluid, etc. and he deduced bad switch, said it was hard to get and that it fell apart when he removed cover. Switch was installed used at dealer when boat was purchased 5 years ago, problem slowly gained in frq since then. Started every time after he replaced switch ( used bomber) on his property and when I got home. After two weeks weather is right, tried to start - cranks strong, faint smell of gas, no fire. Starting fluid no help, I really feel electrical fault somewhere. Clues, anyone? TIA
