  #1
Old September 19th, 2007, 11:59 PM
CAPT.KEITH CAPT.KEITH is offline
Default RPM's going up and down
I need a expert,
I have a 1987 sea ray 340 in it is two MIE 340's My Starboard engine rpms are jumping about every 10 to 20 seconds when running above 2600 rpm,MOSTLY. I need 3200 to plane.
I switch to run off the other tank and was able to run at wot for about 15 min. b-4 I had to return to slip so I went out the next day and it ran about ten min. at wot b-4 the rpm's began to jump around.At this point it early Sep. and the gas is from last season.
tuned last season with wire's,coil,plugs,ignition modular,reman carb.
That being said the reman was no good till this season when I got the right one working all looks good but why is the engine jumping with my rpm's.
Just did a compression test all at 135 psi. all plugs except one looked the same the odd one at the electro was a light tan color ant electro was dry?
Thanks for your time on this matter,Capt Keith
Last edited by CAPT.KEITH : September 20th, 2007 at 07:11 PM. Reason: only talking about one engine
  #2
Old September 20th, 2007, 09:41 PM
rma153 rma153 is offline
Default Re: RPM's going up and down
Do you have ignition sensors in your distributors? - they can start acting up and can eventually cause no spark
  #3
Old September 21st, 2007, 12:05 AM
Hey thanks for your thought's RMA153.
Yes I do and they where replaced last Aug of 06. I've read that some people have gone threw several in a short period of time. And then I lost that thread.The one's that I took off were the older style, they last at least six year's.
Have you heard of a black grease ( from radio shack ) to coat parts to keep them cooler when touching warm plates such as inside the dist.?
Would you be able to tell if the exhaust elbows are supposed to be cool to touch or hot after running.
I'm thinking about throwing on new coil and cap and do that thunderbolt IV test to see if I can narrow it down some more I only have till the end of OCT.
Thanks,again as you can tell this my first post and your comments I believe to be on the right track!
Capt Keith
  #4
Old September 26th, 2007, 01:31 AM
Smile Re: RPM's going up and down
Just for FYI, after compression test one s/p turned up clean, restarted engine and it turns out that I had one s/p wire that was not clicked on the plug.
Thanks for you time everyone.
Captain Keith
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
WOT RPM's vranasaurus Johnson & Evinrude Outboards 82 August 21st, 2005 05:28 PM
not enough RPM's! mikbaek0 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 23 March 30th, 2005 08:53 AM
TOP RPM's ??? 2002SOD Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 October 2nd, 2004 07:16 AM
WOT RPM's and cruising RPM's tony_cliffy Johnson & Evinrude Outboards 21 April 19th, 2004 11:07 AM
max rpm's? mattttt25 Johnson & Evinrude Outboards 8 February 12th, 2003 11:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
