  #1
Old September 19th, 2007, 09:45 AM
Asainz320 Asainz320 is offline
Default 1989 150hp Yamaha head bolt torque?
I did a search and i found that its supposed to be 22 lbs. Is that corect? That feels so weak when im torquing the bolts, i feel its not sealing right. What happens if i torque it lets say to 40lbs ?
  #2
Old September 19th, 2007, 10:26 PM
rodbolt rodbolt is offline
Default Re: 1989 150hp Yamaha head bolt torque?
22 worked for years and years.
at 40? you will be posting about broken 8mm bolts and pulled threads from the block. why ya gotta re-engineer a known good product?
make sure every thing is cleaned,tapped holes have been chased,bolt threads cleaned and coated with pipe sealant,. and assemble it correctly.
its so easy a cave man could do it.
  #3
Old September 20th, 2007, 10:57 AM
Ray Neudecker Ray Neudecker is offline
Right at 30 lbs is when the head bolts break or pull the threads.
  #4
Old September 21st, 2007, 03:28 AM
Ok guys thanks a lot for the advice, 22 lbs it is then. Another question. Should i use silicone on the head gasket? I bought a gray silicone at the auto parts and it says it is for high temperature and designed for torque. It has a rating to withstand 650° F. Will that work if i put it between the gasket and the block on both sides? Thanks
  #5
Old September 21st, 2007, 08:13 AM
no no no
the best thing you can do with that silly cone is walk to the bow and throw it as hard as you can. it has no place on the yamaha.
its really not even good to seal the transom mounting bolts.
if you have to use something then BRP gsketmaker or quicksilver perfect seal will work. but the OEM gaskets come with a heat activated sealer already on the gasket.
biggest thing is surface cleanliness NO WIRE BRUSHES, and surface flatness. it MUST be checked.
why are you trying so hard to re-engineer a decent product ?
  #6
Old September 21st, 2007, 12:01 PM
lol im not trying to re-engineer the product, im just asking so i dont make a stupid mistake later. Once again, thanks a lot for your advice rodbolt.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Gen + head bolt torque elpaso Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 21st, 2008 09:05 PM
Head bolt torque glrichards Mercury & Mariner Outboards 2 August 22nd, 2007 06:09 PM
Head bolt Torque In the dark Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 16th, 2007 08:44 AM
Cylinder Head Bolt torque Spec 110HP 1989 OMC Snapper Johnson & Evinrude Outboards 1 December 28th, 2006 05:52 AM
Head bolt torque ?? KaGee Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 September 21st, 2004 07:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
