Re: timing mode?
found my problem...there is another timing mark on the harmonic balancer against the engine.. this may be common knowledge to most of you but I was using the long one closer to the engine mount. Anyway... I used the other one and was able to get it to 8 degrees TDC. It was running about 180 degrees engine temp. Is that the norm?
