1951 Sears (elgin) 7.5 froze motor
freddyray21
I am working on unfreezing this motor. I have put PB Blaster in the cylinders and down the carb. Any other ideas as to where to put some?
F_R
Re: 1951 Sears (elgin) 7.5 froze motor
Remove the carburetor and reed plate and peek inside the crankcase. If you see rust on the crank and rods it is a lost cause. The lower main bearing seal on those was a weak point, allowing water to enter the crankcase and wreck the bearings.
ELKHUNT
i am working on unfreezing this motor. I have put pb blaster in the cylinders and down the carb. Any other ideas as to where to put some?
take the head off and try to see if you can move the pistons at all--sometimes the rod is frozen to the crank--soaking in diesel fuel works better than blaster
jerryjerry05
I like Marvel Mystery Oil.
Hydrolic oil is good too.
Does the lower unit work?Sometimes the gearcase is locked and the motor won't turn over?
M
mrcrabs
Guest
Simple home brewed Electrolysis can be your frozen small engine friend followed by some kroil penatrating oil and time, you just need to make a good connection to the cylinder wall and set back and watch the action, Safty first...do it outside and not indoors!
twocyclemania
While you have the carb and reed valve off you will have access to the crank. I've managed to free-up a few engines by the following method: Take a teflon pin/cylinder (and inch or two in diameter) to use as a punch. Place it on the the crankshaft counter weight (heavy part of the crank) and tap it with a hammer. Probably a little bit harder than a tap but don't be a caveman. I soaked a two cylinder Firestone power head for over a year with no luck. The hammer and punch method worked. Good luck!
