  #1
Old September 18th, 2007, 09:38 AM
hornek hornek is offline
Question 1995 Evinrude 40 Ignition Woes
1995 E40TLEOD on a 1995 Hydra-Sports Z255
The boat & motor were sold to me by my Dad in 2005 after some time sitting up. I rebuilt the carbs and did Linc-N-Sync per the factory manual at that time and the motor's been running well.
I have had some intermittent starting problems over the last 6 months that I traced to a bad powerpack, which I replaced last week.
In the search for the problem, I also:
1 Disassembled the keyswitch & function tested it per the manual - OK
2 Checked the coil resistance per the manual - OK - manual suggested PP
The spark followed the coil output when I swapped cylinder leads
3 Checked the stator resistance - OK - manual suggested PP
Now the motor will not start on mufflers and backfires when the choke is applied. I've never had problems with backfires previouslyon the muffs or in the water. I'm sure I need to check the timing, but wondered how I could suddenly have an issue like this. Any suggestions? THANKS!
  #2
Old September 18th, 2007, 09:44 AM
Walker Walker is offline
Default Re: 1995 Evinrude 40 Ignition Woes
You probably got the leads mixed up when you were swapping the coils.
  #3
Old September 18th, 2007, 10:01 AM
I considered that as well...I was somewhat frustrated and walked away from it on Saturday. I'll recheck the PP to coil & coil to plug connections. Thanks.
  #4
Old September 18th, 2007, 12:25 PM
If you have an OMC power pack the leads should be color coded. the top lead should be orange with blue stripe and the bottom lead shoud be orage with a green stripe.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1995 Evinrude 40 Ignition Woes hornek Johnson & Evinrude Outboards 1 September 18th, 2007 11:36 AM
ignition woes on '73?, 135hp evinrude dulind Johnson & Evinrude Outboards 1 August 7th, 2003 02:28 PM
ignition woes on '73?,135hp evinrude dulind Johnson & Evinrude Outboards 0 August 7th, 2003 12:40 PM
Evinrude 25 HP, 1983 Ignition woes.... HughN Johnson & Evinrude Outboards 1 June 28th, 2003 10:43 AM
Ignition woes? gunkas Mercury & Mariner Outboards 8 April 18th, 2001 06:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
