fishermanms
- Jul 8, 2007
- 100
I just finished wiring up my old aluminum boat trailer that I just finished restoring. I got my lights mounted up high to keep them out of the water. I'm using the 4 flat hook-up on my 2004 F-150 Super Crew. Trailer Brake lights work fine both sides. Turn parking lights or lights on truck on, both trailer lights work fine. Turn flasers on truck, both trailer lights flash too. Turn left blinker on truck, left trailer light blinks fine. BUT........ Turn right blinker on trunk, both trailer lights blink. I checked the four flat terminal on truck with light tester, everything ok. Fuses ok. The green wire coming from terminal on truck goes to green wire on right trailer light. Yellow wire coming from truck terminal goes to yellow wire on left trailer light. White wire (ground) coming from truck is grounded on trailer chasis. Now .... The brown wire coming from the truck terminal goes to the brown wire on the left trailer light. AND I ran another wire off of that same brown wire coming from the truck terminal to the black wire on the right trailer light. Maybe thats where I screwed up but I figured thats where the black wire coming from the right light went... Whats wrong???? Thanks for any help.. Fishermanms
