SKWalleyechaser
- Aug 17, 2007
- 1
I have a dilemma on my 2 stroke 75HP Merc. In considering to install a Tilt/Trim guage I was shocked to not see what I considered a standard Trim hydraulic setup with the two Trim pins on the lower end of the tilt assembly.
I found a schematic labelled "Tilt/Trim Schematic" for the 75 Merc and it appears the same as mine. There is only one vertical lift cylinder on the motor, does/can this handle both tilt and trim??
In previous boats I've always had the two hydraulic trim pins to "trim" the motor/boat, in or out depending on load.
I'm also concerned about damaging the tilt piston or assembly by mistakenly using a trim that doesn't exist.
I bought the boat a couple of weeks ago (from a dealership) and it was advertised with tilt and trim, but to my fault didn't ask or verify this question at the time.
I guess a second question is if this is both tilt and trim, can I install a "generic" TILT/TRIM guage?
