  #1
Old September 16th, 2007, 12:49 AM
Joe Sergi Joe Sergi is offline
Default 1986 Mercury 175 hp. part throttle Surge
I have a part throttle surge at 3000 to 5000 rpm The engine was rebuilt 100 hrs ago. I just rebuilt the carbs they are wh-46 just rebuilt the fuel pump replaced all lines. runs perfect at idle up to 3000 runs perfect above 5000. the fuel line is hooked directly to the engine. it has a electric fuel pump set at 5.5 psi. I have read the other threads the only thing I notice it doesn't have is a bulb. I prime it with the electric pump. the electric does run through the factory pump. I was out at the lake it started surging I turned on the electric and it did not improve. I would appreiate any help. thank You Joe
  #2
Old September 18th, 2007, 02:55 AM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
Default Re: 1986 Mercury 175 hp. part throttle Surge
I would check the fuel supply by following the below linked Mercury Service Advisory. It will show you how to test the fuel system using a vacuum gauge. This is a good way to find out if your bogging is due to fuel starvation. If the vacuum exceeds spec, then you need to figure out what component is causing it, eg, pluged vent, plugged screen in tank, leaking connections, etc.
http://www.marinepartsman.com/Mercur...2001/EN_17.PDF
If the vacuum test does not show any problems, then I would next check the ignition system. I like to use a Smartach meter to easily monitor secondary voltage while the motor is bogging. If the meter shows that voltage is dropping during bog, then you need to figure out what component is failing using various bench tests described in the shop manual. If the voltage is not dropping during bog, then I would be perplexed and I would be asking for advice on this excellent forum too.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #3
Old September 18th, 2007, 11:45 PM
Thank You for the great information Great site Thank You Joe
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
50 HP Mercury 3 stroke, runs great the surge or just idle jmcrews Mercury & Mariner Outboards 2 September 17th, 2006 10:55 PM
1986 Mercury Commander Controller Throttle Only Button Issues akendall Mercury & Mariner Outboards 1 July 12th, 2006 03:31 PM
Adjusting throttle on 1986 /45hp Mercury Limu1222 Mercury & Mariner Outboards 2 July 3rd, 2005 07:20 PM
94 Merc 115 slight surge at closed throttle nitroowner Mercury & Mariner Outboards 0 May 10th, 2004 11:46 AM
78 3cyl 70HP Evinrude Surge at Full Throttle DVASOLD Johnson & Evinrude Outboards 2 July 11th, 2002 08:53 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
