Re: Adding second battery
1989 23' cuddy w/ shore power, ac/dc fridge, etc...
similar question, if I may, I have 2 batterys and the switch 1, 2 ALL or OFF. How should I use this? like the first reply, 1 to start and run and 2 to run the accessories. Then back on 1 to start and run again?
I also have many wires connected to both batteries. Tired to clean them up when I replaced the batteries recently. I install one for starting and a larger deep cycling for accessories. I hope this was right.
When and what charges when running the enigine, then one I am switched to or both? same question for shore power, I switch to AC and turn on Battery Charger, does that charge only the battery the switch is on or both??
Thanks in advance
