  #1
Old September 15th, 2007, 08:43 PM
High Plains Fisherman High Plains Fisherman is offline
Default Mercury 1974 850 Ignition Problem
Hi, this is my first post, but not my first visit to this great site. I've learned a lot by reading the various threads.
The problem I am having is with an old, beat up 1974 850 Mercury's ignition system. I am not getting any spark on #3 cylinder. I have a 5772a series switch box and pulled the wires from the box to a coil that was firing and hooked them to the suspect coil. It fired great. Then I took the disconnected coil and hooked it to the wires for #3 cylinder and got no fire. This tells me the coils are working properly. That leaves me to suspect that the switch box is bad. Is it common to lose just one cylinder on the switch box, or do I have some other problem that I need to check out? Any help with this problem would be greatly appreciated.
  #2
Old September 16th, 2007, 12:27 AM
ricksrster's Avatar
ricksrster ricksrster is offline
Default Re: Mercury 1974 850 Ignition Problem
Post your serial #. I believe you have a 1976 or a 1977 by your description. 1974 and 1975 had different type ignitions. If you have 4 coils go to this link:
http://www.homestead.com/dolphinmarineservice/Ign5.html
__________________
"Many of the greatest sailors were pukers."--Thorfinn Skullsplitter
  #3
Old September 17th, 2007, 09:57 AM
The serial number on the engine is 3877779. I thought it was a '74 model, but there are many inconsistantcies with this motor, so I am not positive of what it is. I looked on some websites with schematics, and that's the box that is shown on them, and the box that is on it, but my Seloc manual says it should be a different setup.
  #4
Old September 17th, 2007, 10:21 AM
Chris1956 Chris1956 is offline
Wink Re: Mercury 1974 850 Ignition Problem
High, That motor has either a battery/distributor and one coil ignition, or the ADI ignition with four coils. You need to use the correct troubleshooting guide. The year is not that important for what you need to do. They components that can go bad are the coil, switchbox, trigger, stator and rectifier. The manual should help you isolate it.
  #5
Old September 17th, 2007, 10:45 AM
ricksrster's Avatar
I have that 5772 Switch box on my 850. Here are the test numbers.
You will need a voltmeter with DVA to check voltages. You can use a regular OHM meter for resistances.
Stator : Blue to Blue/White = 5800-7000 Ohms. DVA = 180V+.
Red to Red/White = 135-165 Ohms. DVA = 20V+
You should have 180V+ from each of the coil posts on the switchbox to ground.
Trigger: Brown to White/Black and Purple to White = 800-1400 Ohms. DVA = 4V+.
__________________
  #6
Old September 17th, 2007, 08:49 PM
Thanks for the specs and diagram. I appreciate it very much. I do have a question about it though. In the upper left side of the diagram it shows that the pigtail on the coils should be grounded. Is this just when testing or all the time? Mine aren't as they are inside the rubber jackets that cover the bottom part of the coils.
  #7
Old September 17th, 2007, 09:38 PM
CharlieB CharlieB is offline
There should be a black wire on each coil connecting the primary side to ground.
A green/? wire also on the primary side.
The plug wire.
The DVA meter tests must be done to the trigger(s) to determine if it is the triger or the ignition module at fault. You've pretty much proved that the module is not firing the coil, no test to determine why, is the trigger failing to trigger the module, if the trigger output tests OK then you can eliminate the trigger, and then double check the box output again with the DVA meter once more before ordering a box.
Make NO assumptions, these parts get expensive fast.
  #8
Old September 17th, 2007, 10:08 PM
Thanks very much for the info. I am fairly ignorant about outboard CDI system, so I have a quick question. Does the trigger fire four distinct and seperate times (one fire for each coil), or does it fire once per revolution of the flywheel?
  #9
Old September 17th, 2007, 11:08 PM
Motor Boater Bill Motor Boater Bill is offline
The pigtails on the coils should ground to the metal mounting bracket that holds the coils. The wire should be sandwiched between the rubber jacket and the bracket.
  #10
Old September 19th, 2007, 10:28 AM
Thanks Bill, I was curious about that as none of mine are grounded that way. They are all inside the rubber jacket.
  #11
Old September 19th, 2007, 10:17 PM
Quote:
Really? Are these the 339-5288T2 coils? If so, I think the pigtail is the only ground for the secondary winding. Someone please correct me if I'm mistaken on that. However, if I'm correct, these need a good, positive ground. I have those coils on my 1976 Merc 200 and the metal bracket they mount to was taped off when the motor was painted at the factory to leave a bare metal surface where the coils mount. In fact, if you look at the schematic posted above it clearly states "Lead on back side of coil must be grounded" (upper left corner of schematic). Try grounding those leads. The ones that are firing may just be arcing somehow.
  #12
Old September 19th, 2007, 10:39 PM
Thanks again for the response Bill. Yes, those are the same coils. I pulled the whole coil assembly off today, and looked at it closely. The whole mess was corroded and full of dirt, etc. Anyway, three of the coils had the pigtails outside of the jacket like they were supposed to be (it was hard to see them from all the crud), but the coil that isn't firing (even though the coil seems to be good) wasn't grounded by the pigtail. That particular coil had been removed and replaced by a previous owner I'm sure as the pigtail was taped to the back of the coil. I am soaking the housing in solvent and will get all the crud off tomorrow. I wonder if the ungrounded coil fried the portion of the switch box that it connects to. As stated before, hooking the wires to a different coil produced no results, but the suspect coil fired when hooked to a set of wires from a coil that was sparking. Again, I sure appreciate the response about the pigtails.
Last edited by High Plains Fisherman : September 19th, 2007 at 10:41 PM. Reason: Additional comment.
  #13
Old September 20th, 2007, 12:04 AM
I've heard that a bad coil (ungrounded in this case) can damage the CDI box--but I'd say clean up those contacts and try it! Keep us posted.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Hydraulic problem on 1974 Mercury 115. TimDollar Mercury & Mariner Outboards 2 August 16th, 2006 01:04 PM
1974 mercury 650 cooling problem? albert71 Mercury & Mariner Outboards 2 July 17th, 2002 03:08 AM
Mercury 850 (1974)/ Reverse problem texas15 Mercury & Mariner Outboards 3 June 16th, 2002 12:00 PM
Mercury 850 (1974)/ Reverse problem texas15 Boat Topics and Questions (not engine topics) 1 June 15th, 2002 05:24 PM
1974 Mercury 7.5 hp - Starting Problem Banaman Mercury & Mariner Outboards 1 May 23rd, 2001 06:27 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
