  #1
Old September 15th, 2007, 02:15 AM
Newbe15132 Newbe15132 is offline
Default 1969 Mercury 80HP Steering question
Hi,
SN# 8342412
Now does this year have a pulling system? or a tilt tube. I have a tilt tube syle streeing on my boat. I think I would also need a linkage arm. if so would this work?
Heres a few pics of the motor, I have not yet pick it up yet. But I like to know the steering system so I can order the parts.
Thanks for your help
  #2
Old September 15th, 2007, 10:19 AM
Laddies Laddies is offline
Default Re: 1969 Mercury 80HP Steering question
Yes and Yes
  #3
Old September 15th, 2007, 03:40 PM
emckelvy emckelvy is offline
That motor probably ain't a '69, or an 80 HP.
The body is circa '64, but the Lightning Energizer distributor is found on later models. Maybe someone coverted an older motor to electronic ign, or used the 'guts' from a newer powerhead to make a "FrankenMerc".
If you have a pic of the other side, showing the fuel pumps and intake transfer port covers, we would have a better idea of whether it's a 65HP or something else.
Cheers..........ed
  #4
Old September 15th, 2007, 04:20 PM
Scaaty's Avatar
Scaaty Scaaty is offline
Yep, I'm with Ed..looks like an early 65hp (steering rod will probably work OK though)
  #5
Old September 15th, 2007, 05:02 PM
Scatty it has external shift connections and 1965 was the last year for that and all of the first series of 800 had battery CD I doubt if anyone would convert backward just didn't want to rain on some ones parade
  #6
Old September 17th, 2007, 09:21 PM
hi,
i'm sure its a 80Hp it has 4 cylinders and 2 carbs. it got me up on plane and got me to 40mph +/- with a 15' tri hull boat. I got a 17 Pitch prop on it. Vary large. But you would think it would get me up fast, but it takes about 15 secs or so before it gets up on plane, then the motor realy opens up.
Lots of fun :-)
Can anyone tell me the spark plug gap I might use? and what kind of plug? I looked at the plugs and theres like 4 differted ones hehe. I'm sure thats not helpping the motor. I guess if I have the right plugs at the right gap it will start easyer. Takes some time to get it started, but onces its in gear and opened up runs nice.
  #7
Old September 17th, 2007, 09:47 PM
the one pic of motor is the wrong pic. look at the one pic, you'll see a siver lining, and look at the other pics and you'll see its not there. and the red fly wheel is covered, and the other pics its not there.
The last pic is not the motor I have, seller must have made a misstake.
Heres the others pic, I'll take more later of the other side. but it does have a distributor that looks like the one in that one pic (that is not the motor pic).
I all so got the steering connected and works great!
  #8
Old September 17th, 2007, 11:04 PM
outboardformulaclassics outboardformulaclassics is offline
Thumbs up Re: 1969 Mercury 80HP Steering question
Hey, Its Garrett, I am glad to see that you got it running with no problem. I highly doubted that you would have any problems. I'd like to see you post some pictures of your boat. Remeber if you ever have any questions, or need anything feel free to give me a call.
  #9
Old September 18th, 2007, 03:19 AM
Scaaty's Avatar
Quote:
Your knowledge is more like a welcome spring shower..
  #10
Old September 18th, 2007, 03:55 PM
Can you tell me the Spark plug I need and the gap?
Thanks
  #11
Old September 18th, 2007, 04:25 PM
Your last picture shows a 65 HP which will take Champion J4C spark plugs or equivalent (such as Autolite 353). Gap at .025"-.030".
That motor carries a "Stone Age" magneto with coil, points, condenser inside of it. Easy to maintain and resistant to Nuclear Electro Magnetic Pulses!
Cheers...........ed
  #12
Old September 18th, 2007, 07:04 PM
So, its a 65hp not a 80HP
New problem, maybe I need to start a new post. But...
When I first stared to run it, it ran fine. Then, it started to cut in and out. Runs like this (R = rev S = stall)
R R R S R S R R S R R S S R SSSSSSSSSSS
Sounds like the ingnition is being turned off and back on and off And so on.
I'm guessing theres something wrong with the spark. the coil? It just getting wors. Now I can't run it. New plugs. .03 gap
any ideas?
Thanks
  #13
Old September 18th, 2007, 07:50 PM
Video walk through.....
I did a video of the motor maybe it will help. I will take a video of it running tomorow.
http://bhgoodsco.com/MOV00773.MPG
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 1969 80HP wiring gakpuss Mercury & Mariner Outboards 2 October 2nd, 2006 10:07 AM
mercury 80hp stator question zuup_2000 Mercury & Mariner Outboards 2 April 10th, 2005 09:38 AM
1969 evinrude 80hp cblguy4u Johnson & Evinrude Outboards 6 November 28th, 2004 06:06 PM
1967 evirude 80hp/ 1969 rennell cblguy4u Johnson & Evinrude Outboards 1 March 22nd, 2004 06:20 PM
1975 Mercury 80HP Distributor Question jbw857 Mercury & Mariner Outboards 2 October 2nd, 2003 05:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
