da_ardvark
- Jul 31, 2007
- 39
Ok, so last week I bought a used Faria Tach for my 1985 70HP Johnson. It's a model # TC9430C. I also got a wiring harness so I can plug into the control box. I'm confused though. The engine manual says there are 6 magnets in the flywheel. This leads me to believe this is a 12 pole system (6 pulse). Through reading I surmise that #poles/2 = pluse rate, however the back of the tach says to have the setting on 5. Problem is the tach doesn't seem to work on the 5 setting. If I set it to 4 (10 pole) the tach seems, SEEMS to operate. Also the tach has a 6 setting which is NOT listed on the back.
My question is does anyone have any idea what's going on here. I'm tempted to leave it set at 4 but I also want to make sure it's giving me somewhat accurate readings.
Please help me wade thru this.
Denny
Denny
