  #1
Old September 14th, 2007, 08:20 PM
rdgallo rdgallo is offline
Default Changing Trim/tilt motor on 1986 Evinrude
I have a friend that had the trim/tilt motor on his 100 hp 1986 Evinrude go bad. A mechanic (not a marine mechanic) told him that the engine would have to be removed from the boat in order to change this trim motor. Is there any way to change it without removing the engine from the boat?
Thanks!
  #2
Old September 14th, 2007, 10:06 PM
CampionGuy's Avatar
CampionGuy CampionGuy is offline
Default Re: Changing Trim/tilt motor on 1986 Evinrude
Just changed one on my 88 Johnson 110. Once the bolts are out and the FRIGGIN tilt cylinder pin is removed the whole trim unit should tilt out from the top first and then slide out of the transom bracket giving access to the third tilt motor screw. I found it easier to mount the assembly in a vise (gently) to replace and test the new unit. Also to drill and tap a broken mounting screw. Use lots of heat and penetrating lube on the screws.
Hope this helps.
Doug
  #3
Old September 15th, 2007, 05:03 PM
Thanks, Doug, I will pass this on to him.
  #4
Old September 15th, 2007, 06:47 PM
HighTrim's Avatar
HighTrim HighTrim is offline
However he may need to remove the port stern bracket, slide it to the left, and remove the steering to be able to squeeze the unit out through the brackets. No need to remove the motor though.
__________________
Chris
  #5
Old September 17th, 2007, 06:21 PM
Thanks again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 Evinrude 50 HP tilt/trim question jnaarnold Johnson & Evinrude Outboards 2 August 13th, 2007 10:34 AM
1986 85HP Force Tilt Trim Motor danandsaraht Force & Chrysler Outboards 8 February 9th, 2007 07:11 PM
Changing Tilt/Trim motor on 1994 Evinrude 150 brianinGalveston Johnson & Evinrude Outboards 5 July 15th, 2004 04:21 PM
1986 evinrude 40 hp tilt/trim strick3 Johnson & Evinrude Outboards 2 November 16th, 2003 06:00 PM
CHANGING OUT TILT/TRIM MOTOR texasfish Non-Repair Outboard Discussions 7 December 19th, 2001 06:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
