  #1
Old September 13th, 2007, 10:39 PM
jimg984 jimg984 is offline
Default 1978 1150 115HP mercury gas leak 1/8 hose
this is a project motor that I am fixing up to put on another boat......hard starting when cold,,,,,when cranking over several times there is a gas leak on an 1/8 hose,, which comes off a fitting on top of the engine under the flywheel cover,, on the port side just a little to the rear of the flywheel goes down past the fuel pump was unable to trace all the due to darkness... i can see that the rubber hose rotten and open at the top fitting
what is this hose for and why does it leak when cranking over..
why is this motor hard to start,, after 1st start,, starts very as long as warm
rebuilt carbs adjt floats to specs,,
rebuilt fuel pump
all new hose
new impeller
  #2
Old September 13th, 2007, 11:09 PM
Default Re: 1978 1150 115HP mercury gas leak 1/8 hose
this is a inline 6 cyl
  #3
Old September 13th, 2007, 11:23 PM
AMD Rules's Avatar
AMD Rules AMD Rules is offline
Transfer line to provide fuel (lubrication) to the main crank bearings. Fix it.
These inlines are notoriously hard to start when cold. Be sure to prime it well until the bulb is firm, then another good pump (they like fuel). Tilt motor all the way down. engage choke and make sure the choke plates are functioning..... lift fast idle lever and it should start ok.
The newer inline motors used an enrichment solenoid instead of a choke plate system, and this essentially drools fuel in to the carbs to help with starting. You coudl consider switching to this arrangement.
__________________
'72 Glastron GT160 c/w '72, '84 and '86 Merc 115hp
'67 Merc 3.9hp , '70 Merc 9.8hp, '61 Merc 50hp ... The Merc Nut
  #4
Old September 14th, 2007, 12:28 AM
ADM thanks very much for your help on both issuses
both very important espc the 1/8 lub hose
ths again
jimg984 north carolina
  #5
Old September 14th, 2007, 11:53 AM
getting much needed rain in north carolina not able to work on motor where does the 1/8 hose attach to at the bottom,,,,,,
had a suggestion to install an OMC primer from later and later motor
dont know what that is and were to get........ for the hard starting
  #6
Old September 14th, 2007, 11:54 AM
sorry later and larger motor
  #7
Old September 15th, 2007, 08:33 AM
Chris1956 Chris1956 is offline
Red face Re: 1978 1150 115HP mercury gas leak 1/8 hose
That 1/8 hose runs from a nipple on the lower crankcase, next to the bottom main bearing up to a nipple next to the top main bearing. Any oil that collects in the bottom of the crankcase is pumped up to lubricate the top main bearing.
  #8
Old September 15th, 2007, 08:57 AM
SPUNWHEELS SPUNWHEELS is offline
These inline engines use check valves to route the remaining oil from the bottom cylinder main bearing to the top bearing for reburning and needed oiling to the top main bearing. The valve might be a check ball type or a duck call rubber type. This is important to maintain this oil line with these checks in good working order. I couldn't find any mechanic in my town that thought this was a required oil line, and nothing to worry about, but my top bearing burnt that next weekend. My top bearing got so hot it burnt through the distributor drive belt.
I imagine if any air gets sucked into that top seal, it cuts the oiling to the top bearing to nill. The crankcase is operating on pressure and vacuum, so it can suck air into there at times, and you need that extra oil to be dependable and help prevent air intrusion.
You should be able to get this rubber valve at your dealer, or you can do like I did, find a 140 hp inline and use those. These are the metal ball type.
Hard starting is what they do, keep a can of starting fluid handy to prevent killing your starter or your battery. I done some creating plumbing and made a tiny manifold to be able to shoot gas into all 3 carbs with my squeeze bulb. Marc
  #9
Old September 15th, 2007, 10:23 AM
ths thats the best explantion of the hose i have got... i can see that the hose is crackered near the top fitting, i will run until i replace this hose....
do you think i need to replace the rubber valve [which i dont understand yet]
tell me more about your home made manifold and it works with your primer bulb... i was thinking of doing something like this
no mercury dealers in this rural area
thank you again for your help
  #10
Old September 15th, 2007, 01:42 PM
AMD Rules's Avatar
Just a note to add that if you do use 'starting fluid' be sure it provides lubrication and was intended for a 2-stroke outboard motor. Traditional starting fluid contains no lubricants and can harm the motor. Best starting fluid would be a pre-mix of gasoline and twc3 rated oil. Better to find a way to make it easier to start without having to use starting fluid.
__________________
  #11
Old September 16th, 2007, 04:01 AM
crabbie crabbie is offline
This forum still amazes me. Today I carefully took a nice photo of my '75 1500 to point out the very rubber hose discussed in this thread. "What is the hose for?" would have been the question I would post with the photo.
But then someone beat me to it and asked the same question yesterday! Ah well.
*My* hose was cracked right at the top, but fortunately there was enough slack that I could cut off the offending bit and re-attached it. Not before blowing (no go) and sucking (did go) on it, though. Good thing no gooey oil came up it!
rodney
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1978 Mercury 115HP 1150 SDFISHMAN619 Mercury & Mariner Outboards 5 August 16th, 2007 09:36 AM
1978 1150 Mercury Idles To Fast jimg984 Mercury & Mariner Outboards 1 July 28th, 2007 05:39 PM
Grear Ratio 1978 1150 Mercury 115 Hp jimg984 Mercury & Mariner Outboards 4 July 28th, 2007 02:19 PM
What is the top RPM for 115hp Mercury 1150? csmall06 Mercury & Mariner Outboards 4 July 26th, 2004 09:06 PM
Oil for 1978 Mercury 1150?? johnson1 Mercury & Mariner Outboards 3 May 9th, 2003 09:11 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
