  #1
Old September 13th, 2007, 09:01 PM
rude_dude rude_dude is offline
Thumbs up 66? Evinrude 6hp Motor stuck after transporting
OKay, we brought our 66 (we think) Evinrude Fisherman 1600 miles from Seattle in the moving truck. We tried to pack it carefully and packed it upside down on resting on the engine. It seemed like the right way to pack it at the time! The drive lever was broken when we unpacked it and when we tried to start it the rope was will not come out more than a couple of inches or so. We can still shift the drive with a vise-grip and the rope will uncoil and recoil just fine. The flywheel (?? the big metal round thing with a bolt in the middle of it. I know I'm an idiot!!) will not move. It ran perfectly the week before we moved and now it's totally jammed. Any thoughts or helpful hints! Thanks very much.
  #2
Old September 13th, 2007, 09:32 PM
angus63's Avatar
angus63 angus63 is offline
Default Re: 66? Evinrude 6hp Motor stuck after transporting
Welcome!!!!!
Take out the spark plug, squirt some 2-stroke oil in the cylinder, work the flywheel by hand (with the plug out!!!!) back and forth until it turns freely. If it doesn't, we'll go from there!!!
Good luck
  #3
Old September 13th, 2007, 10:34 PM
jspringator's Avatar
jspringator jspringator is offline
I've had both issues you describe, but on 2 different motors. PB blaster freed my stuck cylinder on my 3.5 Tohatsu after 3 days. I broke my shift lever on my Johnson 6 and am still trying to figure out how to fix it.
  #4
Old September 13th, 2007, 10:43 PM
Thanks for the help. I was planning on trying the twc in the plug holes after reading another posting. Just tried it and let it sit for about an hour. Flywheel still not moving. I also changed the lube out which was pretty milky. Any other suggestions??
  #5
Old September 13th, 2007, 10:45 PM
Are you in neutral?
  #6
Old September 13th, 2007, 11:24 PM
F_R F_R is online now
Seattle, huh? So, the last time it ran before being packed, was it in salt water?
Turning an outboard upside down allows any water that has not completely drained out, to run into the exhaust ports. Bad news, and very bad news if it was salt water.
  #7
Old September 14th, 2007, 12:13 AM
rudedude's Avatar
rudedude rudedude is offline
Man,I sure hope no one confuses us.
  #8
Old September 14th, 2007, 12:47 AM
Saltwater it was! Oh no. What does that mean? Anything I can do?
  #9
Old September 14th, 2007, 12:50 AM
Am in neutral. Any help would be great! Was such a good runner before we moved, would hate to think it's junked now because of us transporting it upside down!!!
  #10
Old September 14th, 2007, 02:29 AM
Xcusme Xcusme is offline
Lay the motor down with the plugs pointing up. Remove plugs. Spray PB Blaster into each cylinder and let it work. After a few hours (sometimes it takes days) try rotating the flywheel clockwise. Resist the urge to put a wrench on it to break it free just yet. Sometimes if you get it to turn a small fraction, try rotating the flywheel clockwise and then counter clockwise gently. Using too much force on the flywheel nut can damage the connecting rods, crank, rings etc. Patience is a virtue with a frozen motor.
One last thought...if there's any doubt that your problem isn't in the lower unit, drop the lower unit and try turning the flywheel again. It's it's free, you're problem is in the lower unit. Since you have the lower unit down, replace the water pump impeller if it hasn't been done in awhile.
  #11
Old September 14th, 2007, 05:39 AM
Sounds like you dumped salt water into the cylinders when you turned it upside down. My advice is to remove the cylinder head and exhaust covers and take a looksee at what you have. Also, be aware that the water could have ran into the crankcase as well.
My advice is to forget about the freeing it up with solvents and stuff until you know the extent of the damage. You could make a bad situation worse if you start it up with rusty bearings and toss a connecting rod through the case.
  #12
Old September 14th, 2007, 07:22 AM
bubbakat's Avatar
bubbakat bubbakat is offline
F R has made a good point here. Pull that head and look to see if the wall are rusted from the salt water. Small cost to doing this. I had a six do me this way and that is what I did and if I had forced it to turn loose it would most likely broke the rings but as it was I had just a little pitting on the wall.
  #13
Old September 14th, 2007, 09:54 AM
It takes PB Blaster DAYS to work The books say removing the head and removing carbon and planing the head with emory paper on a known flat surface (like a piece of glass) is a good idea anyway.
I think I did something similar with my Tohatsu last time I used it in salt water in 2004. I laid it on its side. I freed it up 3 years later with PB Blaster. I didn't have to take the heads off, though.
  #14
Old September 14th, 2007, 10:07 AM
Thanks for all the help everyone. I'll attack it this weekend and hopefully we'll have some success. Thanks!
  #15
Old September 16th, 2007, 03:06 AM
Question Re: 66? Evinrude 6hp Motor stuck after transporting
Still stuck! Spark plugs are out and PB blaster has been soaking for over a day. The flywheel barely moves. Just clicks back and forth. Haven't gotten into the lower unit yet, but any other suggestions? Thanks!
  #16
Old September 17th, 2007, 12:37 AM
The fact that the flywheel moves a tad is good news. Now you need to decide whether it is the powerhead that is stuck or the lower unit. I'm still betting salt water in the cylinders. Stick a scredriver into the spark plug holes and touch the piston tops while you click the flywheel back and forth. Can you detect even the tinyest bit of movement of the pistons? If not, they are stuck. However, if they move even a tiny bit, the lower unit is stuck.........Probably. But not written in stone.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
transporting motor on it's back question. htuong95 Non-Repair Outboard Discussions 4 October 31st, 2005 10:14 AM
Transporting Outboard Wild Bill Mercury & Mariner Outboards 1 June 11th, 2005 10:02 PM
Transporting a 4 stroke joe8739 Non-Repair Outboard Discussions 3 June 27th, 2004 02:35 PM
Transporting Outboards In Cab jackpine Non-Repair Outboard Discussions 6 February 25th, 2004 08:41 AM
boat transporting jredding Boat Topics and Questions (not engine topics) 0 October 1st, 2001 08:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
