need help on omc cobra tilt & trim
bassman214
just bought new (used) boat tilt doesent work it just clicks when i hit the button anyone have any advice i took the motor off and hooked it to power motor runs.
Laddies
Banned
Re: need help on omc cobra tilt & trim
It sounds like a bad solinoid, you will get more responces in the I/O forum
Gary H NC
If it runs with direct power then most likely the solenoids have bad connections or have failed.Clean all the connections shiny clean.
Also check the two 50 amp fuses in the rubber boots behind the solenoids..
