Rough Idle..Where to start?
jedimaster
3.0 mercruiser, 1988 140hp
The engine is running great while under throttle Getting 3600rpm at wot with a 19 pitch 3 blade alluminum and good power out of the hole.
But it idles really rough.
I have set the timing, has had a can of seafoam run through, rebuilt the carb(idled rough before as well), Replaced the plugs and wires.
What next? I have the RPM's at idle set at 800. If I raise it to 1,000 rpm idle it seems to idle fine? Is the idle mixture out maybe? or should I just turn up the idle rpm's?
It will eventually stall as it almost sounds like its running on 2 cylinders, its really rough.
Zero Balance
Re: Rough Idle..Where to start?
Put a vacum gauge on it and see whats what. Could be one of several issues, vac leak, air mixture, bad fuel.....
With a Full,+ Complete Tune-Up.............
Idle spec is 650/ 700rpms, at idle, in gear, in the Water..........
At 800/ 1000rpms,...... All you're going to do is Trash the Outdrive.........
Don S
You may have more wrong than you think, your WOT rpm is about 1000 rpm LOW. you should be seeing between 4400 and 4800 rpm at WOT.
Run a proper Compression Test before you do a tuneup.
jedimaster
Sorry, meant to say 4600rpm at wot not 3600
Where do you attach the vacuum guage?
jedimaster
Compresion is good on all 4 did the head gasket this spring.
