I recently bought a used 20 hp mercury that won't tilt up when in forward gear; tilts up when in reverse. I was told by someone at work that this may be due to lower unit not being reinstalled properly after water pump impellor replaced. Something about the shift lever being in the wrong position for the gear it is in. Could anyone advise if this is possible and what position the shift lever and gear dog need to be in if I remove and reinstall lower unit.
Thanks for any help
Thanks for any help
