  #1
Old September 11th, 2007, 04:40 PM
mikehooper420 mikehooper420 is offline
Default Key switch diagram for a 1964 evinrude starflite 90s
I recently bought a really old boat with a 1964 evinrude starflite 90s. The guy that sold it to me swears it ran about 8 months ago, and he has no reason to lie cause I already gave him the money and live 1000 miles away from him. The starter was burnt up, so I had it rebuilt, the lower unit was rusted up so I replaced it with a rebuilt one, and the key switch was missing the key so I bought a new key switch. My question has two parts: first where can I get a keyswitch wiring diagram all the ones I have explain with the wrong color wires involved. And the second is: Why does the new lower unit have a larger gauge wire than the old one. Is it because its a hydroshift and the other is electric, I don't know what kind either of the lower units is
  #2
Old September 11th, 2007, 05:24 PM
F_R F_R is offline
Default Re: Key switch diagram for a 1964 evinrude starflite 90s
A heavy brown wire with a fuseholder in it from ammeter Gen Terminal to key switch Bat terminal
A white wire goes to the key switch Start terminal
Four red wires, plus a red/white striped wire goes to the Key switch Ignition terminal.
Now, it gets confusing:
The original setup had a wire from the choke override switch to the key switch Start terminal, along with the white one....However,
The override switch may have been changed to a choke switch. In that case, the wire from it goes to the key switch Ignition terminal along with all those red ones.
The electric clutch lower units and the hydroelectric lower units are not interchangable. Hydro-electrics have the exhaust exiting through the hollow propeller hub.
  #3
Old September 11th, 2007, 07:07 PM
Thank you so much you are the first sourse with the right color wires I have been able to find, but tell me how do I tell if my lower unit is hydro electric or electric. WIll the shaft be hollow where the propeller goes
  #4
Old September 11th, 2007, 08:49 PM
F_R F_R is offline
If it is a 1964 it is electric clutches. Hydro-electric wasn't even invented till 1968. Yours has a plain old regular propeller. Hydro-Electrics have a hollow hub propeller with a hole in the center that you could jam your fist into if it were not for the shaft being in there. So do a heck of a lot of newer motors that are not Hydro-electric.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1964 Evinrude Starflite 90-s; Need some Info. Ranger01 Johnson & Evinrude Outboards 12 June 24th, 2009 01:00 PM
1964 evinrude wiring diagram kesner03 Johnson & Evinrude Outboards 1 September 11th, 2004 11:57 AM
1964 90s starflite woes McAdam Johnson & Evinrude Outboards 3 August 4th, 2004 04:04 PM
1964 Starflite 90-S, need help to rebuild . . . MikeB99GTP Johnson & Evinrude Outboards 6 October 24th, 2003 09:45 AM
63 75 hp evinrude starflite II, diagram cwexcel Johnson & Evinrude Outboards 0 August 7th, 2003 12:11 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
