  #1
Old September 11th, 2007, 02:47 PM
igofishn igofishn is offline
Default Yamaha Dual Controls Problem
I have twin 1991 150 yamaha's. I normally cruise at 3,600 rpm and both controls are at the same foward postion. My last few trips I noticed that I have to move the starboard control about 3/4 inch further forward in order to get to 3,600 rpm. Since this started, once in a while this motor rpm surges up from 3,600 to 4,000 then back down to 3,600. Both controls move in and out of gears with no problems. Is this a start to a problem with this motor or are the control cables starting to fail or need adjustments? Any help would be appreciated.
Thanks
  #2
Old September 12th, 2007, 05:33 AM
rodbolt rodbolt is offline
Default Re: Yamaha Dual Controls Problem
as the cables are a single strand of solid stainless, I would say your engine is developing an issue. when was the last time you brought them up to WOT together ?
  #3
Old September 12th, 2007, 09:36 AM
Enginees are getting old or are old and I don't like to push them very hard. I can't say the last time I ran WOT. Maybe the beginning of the season up here and I don't recall having any issues. I am going to run the boat later today. Is there anything that I should look for while at WOT. I should get 5,000-5,500 rpm? This engine does sneeze once in a while when first started but once warmed up runs ok.
Thanks
  #4
Old September 12th, 2007, 08:44 PM
Shoesole480 Shoesole480 is offline
Quote:
Thanks
Remove the engine covers and place both throttles at W.O.T. and ck. to see if you are getting the same throttle lever position on both motors (should be just before break-over point @ throttle-shaft) Also, check to see if timing base linkage is in good shape with no slack or loosness and ck. to see if timing base moves smoothly as you throttle up and down. If all checks out ok, the you should ck carbs/fuel delivery. Also, never neglect the spark plugs, they are too often over-looked. I can't begin to count all the times I had a hair-pulling problem that finally came down to spark plugs. Spark plugs can test fine in the shop, but under operating conditions, I have seen too many of them fail at higher RPMs.......good luck
  #5
Old September 12th, 2007, 11:00 PM
I didn't get a chance to get down to the boat today. But I will try what you said. Also, This season I replace the 2 fuel pumps, spark plugs and fuel filter. Everything was fine up to a week ago. I will pull the plugs and inspect them. Also I will check the fuel pumps maybe the sneezing messed up one of the fuel pump diaphrams. I have never cleaned the carb's in the 10 years I owed this boat, it might be time? I have heard that it should be done every 3-4 years! I have had only very minor problems with these engines in the past. They have been very relaible. Thanks for you response. I will let you know what I find.
  #6
Old September 13th, 2007, 09:49 PM
Rodbolt,
I ran the boat today WOT, 5,000 rpm on port, 4,800 rpm on the starboard motor. Also, ran boat at 4,500, 4,000 and 3,600 and the boat didn't sugre today but the starboard throttle is still about 3/4 inch ahead of the port. I noticed today that when I lowered the engines into the water there was some fuel in the water? The boat started fine but it started sneezing at idle. I reset the pilot screws to 1.250 turns out from the seated position but still sneezing. Is there any tolerance of a .25 turn futher in or out on that setting? Maybe time to clean carbs?
Thanks for your time.
  #7
Old September 14th, 2007, 08:08 AM
it may well be.
if both engines magneto arms contact the arm stopper then I would look for engine issues.
cable stretch is just not likly on that setup.
  #8
Old September 14th, 2007, 09:47 AM
Both magneto arms are hitting the stop at WOT like you said. The 200 rpm differecence is that something to be majorly concerned about. I have about 4 weeks left to my season another maybe 10-15 hours or so of runnng, would you run this way and pull down the carbs during the off season? Also that fuel in the water I see is that normal, never noticed it before?
Also, my port control is alot tighter then the starboard is there a tension adjustment on them?
Thanks again
  #9
Old September 23rd, 2007, 01:53 AM
Smile Re: Yamaha Dual Controls Problem
Sorry for the long delay but I pulled the carbs off last week. Found a broken pilot screw in the lower carb. Pin was stuck in the opening so I purchased a new carb and rebuild kits. Soaked and cleaned and rebuilt the carbs. Checked compress 113-115psi on all 6, changed plugs, fuel filter, fuel pumps and water seperator. Installed carbs this morning and engine purred like a kitten. That engine always had a slighly rough idle since I purchased the boat, not any more. 5,000 rpm on both motors now and throttles are at the same position.
As you stated in other posts, rebuilding the carbs was not at all difficult.
As always, thanks again for steering me in the right direction guys.
Now back to Striper season.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Best Dual Engine Controls & Shifters Christos Boat Topics and Questions (not engine topics) 2 September 9th, 2007 01:11 AM
Merc Dual Controls coach88 Mercury & Mariner Outboards 0 August 31st, 2007 12:15 AM
Dual Batteries On Yamaha 130 nickfishbait Yamaha & Suzuki Outboards 6 October 20th, 2006 05:14 PM
dual lever controls phatmanmike Non-Repair Outboard Discussions 1 July 12th, 2004 12:13 PM
Dual controls for johnson beach Johnson & Evinrude Outboards 6 June 30th, 2003 05:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
