Re: 1985 evinrude stuck in reverse
I start engine in neutral everything is normal..when i drop it into reverse it goes in smoothly and runs normal..when i try to go from reverse to neutral the shifter works but it stays in reverse and engine revs faster. I can remove engine cover and manually put it into neutral but NOT forward.
