  #1
Old September 11th, 2007, 10:49 AM
napicker napicker is offline
Question Mercury 150HP Outboard Tell Tale not working
I recently bought a 1987 Boat with a Mercury 150 outboard. The boat runs great on the water no troubles. I have had it out over a dozen times. However the tell tale has never worked. I haven't noticed any problems but I am not sure if this is supposed to be working for engine cooling. I just checked the tubing and there was a small rubber peice that I removed.Can someone let me know if this should be fixed before taking on the water again. Thanks.
  #2
Old September 11th, 2007, 10:54 AM
fishingdan fishingdan is offline
Default Re: Mercury 150HP Outboard Tell Tale not working
These 150s had a poor design for the tell-tale port. No real stream of water will come out of the tell-tale until the t-stats are wide open. If you boat in colder water, I have noticed that this may infrequently happen. If it does, it is only for a short period of time.
Do you have an engine temp gauge? You need one for these engines.
  #3
Old September 11th, 2007, 10:58 AM
Silvertip Silvertip is offline
Push a piece of string trimmer line into the line to make sure its not clogged with debris or sand.
  #4
Old September 11th, 2007, 11:35 AM
drewmitch44's Avatar
drewmitch44 drewmitch44 is offline
silver does that work? How far will it push in? Will it go all the way through the cooling passages? Just curious.
  #5
Old September 11th, 2007, 11:47 AM
If you want to make sure the tell-tale line is clear, it is easy to open the engine cowling and run air or water through from the thermostat exits (top of the head with hose connected to it). While you are there, check your thermostats.
I did the same thing you are doing. At one time, I removed the t-stats just to prove that the tell-tale was clear. It pumped a strong steady stream at idle when that occurs (as it should). Don't operate the boat on the water without t-stats
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
tachometer not working with 25 hp Mercury outboard szn9rg Mercury & Mariner Outboards 4 August 7th, 2006 12:11 PM
92 150hp mercury outboard overheating jfrunzar Mercury & Mariner Outboards 2 June 20th, 2006 02:56 PM
1997 Mercury XR6 150hp tell-tale stream is hot !! calm like a bomb Mercury & Mariner Outboards 18 December 12th, 2005 09:22 AM
1965 150hp mercury outboard from germany tbone2330 Johnson & Evinrude Outboards 0 September 17th, 2003 06:45 PM
reverse is not working on my mercury outboard fishinntx Mercury & Mariner Outboards 0 September 2nd, 2002 07:17 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
