Re: mid 80's 115 trim tilt problem
The bleeding process for the engine is with the motor tilted all the way up, fill the system and run thru 4 or 5 full tilt cycles then tilt all the way up and refill, do the process till bleed. If that don't fix it you have 1 of 3 problems,
1. tilt ram has a ball not seated(dirt or bad seat)
2. bad o-ring on the tilt ram
3. the pump is defective
