Re: Replacement fuel pump for a 1966 33hp Evinrude?
If it bolts to the intake port with no air hose running to it, then pretty much any of that style "large" pump will work with the same set-up. Used on 20hp to 75hp motors from the 1970s on up...
If it bolts on the exhaust cover, has a glass sediment bowl and has an air line running from the intake port cover, then any of the fuel pumps of that style (casting #377113) will work...
- Scott
It mounts on the side of the motor. It has one gas line in and one gas line out. In the back it has a hole that mounts on the motor that also has the hole. Any part number?
The Sierra 18-7351 sold here at iboats and everywhere else, will work just fine. The hoses come out at a different angle, but who cares. It is a direct replacement for 438562. Don't pay any attention to the 9.9-15hp application. That's just because of the hose direction.
