Ok Guys
Im almost done working on my boat. The tach that came with the boat didnt work. I just got a new faria 20 pole tach on ebay and hooked it up to the harness and got power to the light and the needle went up to zero. Havent fired up the engine up yet.
Only thing I cant figure out is the signal wire. The purple generator wire was hooked up to the old tach but on the terminal strip on the engine its labled tach for the white wire. When I looked under the dash I found the white wire but it wasnt hooked up to anything. So which one do I use ? Seems the white wire is coming off the ignition coil. Really dont want to fry the new tach so any one with a 85 50 hp engine could you let me know which wire to use.
