  #1
Old September 10th, 2007, 01:04 AM
jhedgeti jhedgeti is offline
Default 25hp Evinrude Sportster starting problem
Not sure what year the 2 stroke 25hp Sportster is. The spark plugs spark- very little gas gets to the plug- compression feels good- tank is properly vented. It will not start or even give a hint of starting. Could the gas line be blocked ?? If so what can be done? Is it the fuel filter?
Thanks for any help Jack
  #2
Old September 10th, 2007, 06:24 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 25hp Evinrude Sportster starting problem
more history, model number, has it been sitting a couple of months or years. last service done to it. go to the engine faq forum, read outboard won't start, and awakening a sleeping outboard.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old September 10th, 2007, 11:16 AM
samo_ott's Avatar
samo_ott samo_ott is offline
As well as what TD said, try spraying some 50:1 premix in the carb and see it it catches at all. If so then you have carb probs. If not you have ignition probs.
  #4
Old September 10th, 2007, 02:49 PM
BF BF is offline
I have a 1970 25 hp sportster... when I first got mine, I found out the spring that activates the choke butterfly on the outside of the carb had a notch worn into it, so would catch and the choke would usually not work properly (but occasionally it slide over the catch and it'd work ok)...
I took the carb off, took that spring off, and unwound it 1 coil so that it was smooth at the point that it rubs on the butterfly cam... the choke's been working well for ~ 5 years now. When I found this, I figured it must be a really common problem on these oldies, but I've never heard of anyone else having it.
Anyway, it's something for you to check. Good luck.
  #5
Old September 11th, 2007, 06:27 PM
The serial number for this engine is 25103S - E02944. That is the number on the plate which is on the lower shaft. How does this number help?? Where can I find out what the number means?
Thanks - Jack
  #6
Old September 11th, 2007, 06:42 PM
cr9c1 cr9c1 is offline
You have a 1971 Evinrude 25 HP
  #7
HighTrim's Avatar
HighTrim HighTrim is offline
Its a 71
__________________
Chris
  #8
Old September 11th, 2007, 06:49 PM
JB's Avatar
JB JB is offline
Go to the Engine FAQs, Jack. Do the "Outboard won't start" troubleshooting.
Let us know what you learn.
Good luck, and welcome to iboats.
__________________
RED SKY at night. . .
JB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
'71 Evinrude 25HP Sportster Gas Mix? FirNaTine Johnson & Evinrude Outboards 1 August 20th, 2007 08:11 PM
Evinrude Sportster 25hp - year? minniemousey1 Johnson & Evinrude Outboards 3 May 20th, 2007 07:29 AM
1972 Evinrude 25hp Sportster harveyg Non-Repair Outboard Discussions 1 September 24th, 2004 04:09 AM
Evinrude 1978 25hp - problem starting on both cylinders tmeo Johnson & Evinrude Outboards 1 September 12th, 2004 07:01 AM
1970 Evinrude Sportster 25Hp fxpthl Johnson & Evinrude Outboards 1 May 13th, 2001 12:47 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
