  #1
Old September 9th, 2007, 06:47 PM
cr9c1 cr9c1 is offline
Default 1972 Evinrude 25 fuel problem
I have a problem with my 72 Rude 25hp sportster. I thought I had it figured out over a year ago but apparently I am mistaken.
It has a fuel leak and it appears to be coming from the throat of the carb. I've ruled out all other places, fuel pump has been rebuilt, all hoses are new/replaced, engine gaskets are new, etc. I haven't rebuilt the carb yet (And I know I should, and I am going to asap) but I'm wondering if there is something in the carb that would allow fuel to blow back out the throat? I've also replaced the reeds to rule those out as well.
Input appreciated!
  #2
Old September 9th, 2007, 10:07 PM
jwilkey84 jwilkey84 is offline
Default Re: 1972 Evinrude 25 fuel problem
why would you do so much other work before rebuilding the carbs?
  #3
Old September 9th, 2007, 10:17 PM
Xcusme Xcusme is offline
Sounds like the carb rebuild is next as the float needle isn't sealing and allowing the fuel to flood the carb....
  #4
Old September 10th, 2007, 01:31 AM
Float operation is correct. I've replaced the carb with another and when I did I went ahead and put a needle and seat into it.
  #5
Old September 10th, 2007, 06:26 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
if you have done all that, i would say the float needs to be adjusted,
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #6
Old September 10th, 2007, 08:36 AM
Yeah. I'll adjust the float tonight. Im assuming that the appropriate adjustment is as J. Reeves suggests, and the opposite side of the hinge should be slightly higher than the hinged side.
  #7
Old September 10th, 2007, 09:51 AM
when turn upside down, should be inline with the carb body, or the free side a little higher. so are extremely touchy.. i've had several i've had to adjust 2 or 3 times to get right. attach a hose to the inlet and blow with it upside down, no blow good, leak no good.
__________________
FLORIDA GATORS
TEBOW Country
  #8
Old September 10th, 2007, 10:20 AM
i386's Avatar
i386 i386 is online now
Quote:
Good tip, thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1972 Evinrude, 50, ran out of fuel-now no start newuserguy Johnson & Evinrude Outboards 2 June 17th, 2006 04:21 PM
1972 100 HP Evinrude Starting Problem Driveline Non-Repair Outboard Discussions 1 September 6th, 2003 12:22 PM
1972 100 HP Evinrude Starting Problem Driveline Johnson & Evinrude Outboards 1 September 6th, 2003 12:22 PM
1972 85HP Chrysler -- Fuel Problem?? turtle1173 Force & Chrysler Outboards 11 August 8th, 2003 06:16 AM
fuel pump problem for 1972 evinrude 85 hp pillatzki Johnson & Evinrude Outboards 2 August 7th, 2003 04:37 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
