  #1
Old April 1st, 2003, 05:49 PM
sidthekid sidthekid is offline
Default aluminum boat with pinholes
I'll try to describe this as best as I can. I pulled my son's 14' boat out of the water last year and had to scrape quite a bit of barnacle growth off the bottom.The water here is brackish.I then hosed off the boat and stored it bottom side up for the winter.Apon close inspection last week, in order to get it ready for bottom paint, I noticed that everywhere there was a barnacle there is now a small area that looks to be corroded.These areas are 1/8 - 3/16ths in diameter.At the very center of alot of this are very small holes, the smallest being the size of a pin,the largest being the size of a sixteen penny nail.There is around 50 of these.What the heck do I do to repair this?? The only thing I could come up with is that Rhino lining they spray on pickup truck beds. It looks tough and is flexible.I've asked the marine stores and no help there.The rest of of the boat is in great shape so I would like to try and save it.Thank you in advance for any help...Sid
  #2
Old April 1st, 2003, 06:01 PM
Reel Appeal Reel Appeal is offline
Default Re: aluminum boat with pinholes
sid, A two part epoxy designed for aluminum may be the ticket.Hardware store should have it.Patch each area individually.Sand if needed.
  #3
Old April 1st, 2003, 06:19 PM
JB's Avatar
JB JB is offline
Hi, Sid,I like your Rhino-Liner idea. I think that's what I would do.Good luck.
__________________
RED SKY at night. . .
JB
  #4
Old April 2nd, 2003, 03:29 AM
FlyBoyMark FlyBoyMark is offline
Ensign
Another alternative is to weld.....clean with ss wire wheel on drill, both sides. Weldor should charge about 50 to 80 bucks. Make sure he knows what he's doing....the little dimples of weld should be so small that you would not normaly notice them and he must use 5356 filler. Set up for the tig job is 1/16" tungsten, 1/2" ceramic nozzel and .45 size filler, machine set to less than 100 amps. If you don't see this he's going to do a hack job with grapes. Pre cleaning as I said will save you a ton of money and make the weld job go much easier for the weldor. Any other forms of repairs are temporary at best.
  #5
Old April 2nd, 2003, 04:06 AM
dkondelik dkondelik is offline
'Mornin'Sid,My wife found an ol' aluminum boat for me toplay with. Rhino was pretty pricey at our local parts store but they had a similar product on the same shelf. I used the stuff and it seems to work GREAT. The boat lands in the sand alot. I figure, if/when the liner wears down/off, I can just re-spray and it'll be good-to-go again.Good LuckHAVE FUN!
  #6
Old April 2nd, 2003, 02:57 PM
cpasseno03 cpasseno03 is offline
I was gonna mention Rhino Liner but obviously your one step ahead of me. I forget where I first heard this idea but it really sounds like a winner to me! I have never talked to anyone that has actually done it though.. I have a steel boat that is no thicker then a rusty license plate in areas... Klondike, how did that work out for ya? And if you dont mind, what did it run/what was it called/ how much did it cover? Let us know what you wind up doing Sid, and for the pinholes, paint alone would keep me asleep at night, but 1/8" is pushing it for paint alone. My opinion and you know what they say about those!Craig
  #7
Old April 8th, 2003, 03:42 PM
Thanks for all the replies. As soon as it clears up again I will try the do-it-yourself Rhino lining and let everyone know how it went. The Walmart here sells it for about 35.00 dollars a gallon.The Rhino dealer here wanted 225.00 dollars and I was going to do all the prep!Thanks again...Sid
  #8
Old May 14th, 2003, 03:57 PM
Well, I finally finished the repairs and here's the scoop: I used a stainless steel power brush to prep the bottom, then I used bondo to fill in the pinholes and just enough to fill in the corroded spots that were not quite holes yet.Then I bought a can of spray on truck bed lining at the auto parts store at $8.00 a can. I figured this should be easy.Then I realized it was going to take 8 or 9 cans.It also went on kinda thin and skimpy.Plan "B". Went to Walmart and bought two quarts of roll on or brush on truck bed liner at $15.00 a quart.I'm here to tell you that this stuff is FANTASTIC!! This stuff is like part of the boat now, very tough and hard finish.It went on alot thicker then the spray on stuff.You have to work a little quickly,it skins over fairly fast.Two quarts was perfect for this size boat.(14 foot) Mix with some sand or whatever and this stuff would also make great non-skid.So, anyway I finished up with bottom paint and it goes in the water tommorrow.Hope this helps someone out there with a simular problem.Feel free to ask any questions and don't ever under estimate Walmart!!....Sid
  #9
Old May 14th, 2003, 06:43 PM
wayne h wayne h is offline
Master Chief Petty Officer
this might be a stupid question but u used it bed liner on the inside of the boat?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
7.5 HP on 14" Aluminum Boat?? garybli Non-Repair Outboard Discussions 11 January 15th, 2007 08:28 AM
aluminum boat... aluminum stringers? diaboy5681 Boat Restoration and Building 6 October 17th, 2006 09:17 AM
Refinishing aluminum boat for camo duck boat noluck127 Boat Topics and Questions (not engine topics) 1 January 9th, 2006 04:47 AM
Refinishing aluminum boat for camo duck boat noluck127 Boat Topics and Questions (not engine topics) 0 January 8th, 2006 06:31 PM
12 ft aluminum boat max hp kdc2000 Boat Topics and Questions (not engine topics) 19 December 20th, 2002 12:59 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
