  #1
Old September 7th, 2007, 10:41 PM
dbueffel dbueffel is offline
Question 1979 50Hp Mercury loss of power
OK, I am new to boating. I have a 1979 Mercury 50HP outboard that will idle fine and run at top speed for the first 10 minutes then will start to bog hard at anything greater than 1/2 throttle. I pulled the plugs and replaced them as they had serious carbon deposits on them. The fuel is new mixed 50:1 and the vent cap is open.
I looked at the carbs today when I got home after trying the new plugs and both barrels are moving.
Any suggestion son what to look for next. Not quite sure the motor will run great for 10 minutes and then act up.
Any help would be appreciated.
David
  #2
Old September 8th, 2007, 11:56 AM
davebad22 davebad22 is offline
Default Re: 1979 50Hp Mercury loss of power
As the motor starts to bog down, have some squeeze the primer bulb to force fuel into the system. If the motor picks back up then you know the problem lies in the fuel system. Check fuel lines for leaks, rebuild fuel pump. I have a '82 40hp. The diaphragm on my fuel pump got stiff and wouldn't push enough fuel to run at WOT. (wide open throttle) Motor would run fine all day long at 3/4 throttle but would start to bog down after about a minute at WOT.
Good Luck
  #3
Old September 9th, 2007, 10:04 PM
Thanks, I will give that a try.
  #4
Old September 9th, 2007, 10:13 PM
saltfisher saltfisher is offline
I sort of have the same problem. I have a 150 merc 1988. It runs good anything 3/4 throttle and less, but after about 20 seconds at WOT it will feel like im lifting back on the throttle, and if i accually dont back off the thottle to match my speed, it will come to a stop and shut off. Then it will be hard to start back up. Almost like its flooded. I may be pushing to much fuel, but dont know if thats possable. It runs fine if i run WOT in short bursts and then back off to 3/4 throttle. is this what yours is doing?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 Evinrude 70 surge in power/loss of power huntingjustinlouise Johnson & Evinrude Outboards 6 April 8th, 2006 05:36 PM
Mercury 50hp-500 power loss at WOT blarsson Mercury & Mariner Outboards 10 July 8th, 2005 04:20 PM
1985 Mercury 50HP Power Loss kayjay Mercury & Mariner Outboards 0 July 7th, 2003 08:21 AM
Mercury 50HP 4-stroke power loss Steve6964 Mercury & Mariner Outboards 2 April 29th, 2003 12:14 PM
Mercury 50hp power loss Steve6964 Mercury & Mariner Outboards 3 April 21st, 2003 11:08 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
