engine starts fine,compression on all 3 is 120psi..engine cold or hot ..it's the same..
put new plugs in ngk BR8HS,gapt 32'
after 10 min. running top cyl. plu is verry wet and oily and black..
2e cyl. is not as bad as nr1,but wet and black,nr3 cyl is white and dry....
engine doesn't sound like it not missing out of the water..
spark seems to be all the same
but engine seems to have no power,won't pickup speed..
sometimes it sounds to run on only one cyl,will pickup 2e cyl ones in a while when we have it in the water under load
does anyone have any info on this?
any specs on the carbs??
thanks,
tommytire
thanks,
tommytire
