speedpeddler
- Aug 9, 2007
- 3
I've got a 2001 ox66/250 with almost 1,000 hours that has run rough and fouled plugs since the day it was new. I've had every tech in town, (Jupiter Fl.) work on the boat without success and am just about ready to unbolt the damn thing and bury it at sea. At this point, I'm convinced the techs have no clue or are to lazy to take the time to properly diagnose the problem. Any ideas what to look for would be appreciated.
The engine usually fouls the bottom plug on each bank at the same time. I can be running along nicely and will begin to hear an occasional miss that soon turns the engine into a five cylinder and shortly after a four banger. Mostly it's the two bottom cylinders but can also be the two top cylinders. A quick change of plugs and I'm off again for a few more hours and it happens again. It also won't hold a steady rpm., ever. Jumps around 500 to 600 rpm without touching the throttle. Any ideas before this engine goes to the bottom?
