  #1
Old September 6th, 2007, 04:06 PM
austin_colby austin_colby is offline
Default 1978 70hp Mercury Outboard Water Around Spark Plug Issue
I just replaced the impeller on my '78 Merc 700 and the water jacket cover seems to be leaking around all three spark plugs. It never did this before the new impeller but I noticed quite a bit more water pressure from the pee hole now. After reading about 20 or so posts about this common problem, I have come to the conclusion that I would like to either a) put some marine quality high temp silicone around the cover or b) just leave it alone. It doesn't appear to affect anything and the motor runs just fine, just a drip here and there from the cowling cover. Any advice would be appreciated.
-Austin
  #2
Old September 7th, 2007, 12:17 AM
Yepblaze's Avatar
Yepblaze Yepblaze is offline
Default Re: 1978 70hp Mercury Outboard Water Around Spark Plug Issue
You are correct in assuming it can be let leak without much problem. (other than erosion making it worse after time.
I have in the past, cleaned around base of spark plug real good with wire brush and solvent with plug in place.
Blow dry.
Then remove plugs, (usually use new ones at this point).
Take the plug and with washer in place squeeze out a 1/8" bead around the threads just below the washer.
Now the hard part, WAIT a few minutes for the silicone goop to start to skin over. About 3-5 minutes on a warm day in the shade.
Then screw in plugs, the silicone should goosh out into the clean cavity and seal it up. Wait a few hours before using it to let the goo dry.
  #3
Old September 7th, 2007, 10:58 AM
Texasmark's Avatar
Texasmark Texasmark is offline
You answered your own question. Yes your pressure is now higher resulting in the discovery of a leaking water jacket cover, probably due to corrosion at the gasket/cover interface....common problem.
No it hurts nothing at this point if you don't mind a little water residue. Over time, if it continues to leak it will get worse, because corrosion will get worse and one day you'll have to change the gasket......really quite simple.....as long as your screws cooperate and come out like they are supposed to.
Since others seem to have a successful repair with silicon go for it. What the heck.
Mark
  #4
Old September 7th, 2007, 09:02 PM
Plainsman's Avatar
Plainsman Plainsman is offline
I learned the hard way and insisted on changing the seal. I broke something like 10 bolts and it cost over $200 to get them out.
Use the marine grade sealant to stop the leak.
__________________
Rest in Peace Spinner
1978 SSV-176 Glastron with a 1976 115 hp model 1150 , 1972 Mercury115 hp
Your friend,your partner, your defender,your dog.You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion....by E.F. Henry
I am NOT a mechanic, but I did stay at a Holiday Inn Express
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
spark plug gap 1978 johnson 115 v4 1978 DCS Johnson & Evinrude Outboards 3 August 10th, 2006 02:27 AM
Spark plugs 1978 mercury thunderbolt 70hp AJ in NH Mercury & Mariner Outboards 1 June 30th, 2006 01:10 AM
2000 mercury 3.3 hp outboard spark plug jhynes Mercury & Mariner Outboards 0 June 13th, 2006 09:10 PM
1971 Mercury Outboard 7.5 HP Spark Plug Question Gruber74 Mercury & Mariner Outboards 1 November 9th, 2004 12:40 PM
1978 70hp 3cyl - spark plug and timing questions agrazela Mercury & Mariner Outboards 4 September 24th, 2004 07:28 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
